https://www.almouachir.com/
hello
i would to change my website from english to arabic for my people arabic so help me to find rtl.css file or create it
For the moment the theme does not have all the elements RTL, but soon there will be a theme update with some fix for this, and will include some new demos in RTL.
Right now there are 2 solutions. You keep the WordPress in English and you adjust only the layout in RTL using the tagDiv Composer so in this way everything will work correctly, or solution 2, set the WordPress in a RTL language, this will set the backend and frontend in RTL, but some options will not feet until the coming theme update.
If there is something that we can do to help, let us know and we’ll try our best!
