Bonjour, Hello,
Tout d’abord merci pour votre travail. J’adore !
Mais j’ai un gros soucis avec mon hebergeur, qui me menace de fermer mon site parce que j’utilise trop de ressources.
Savez vous d’ou cela viens ?
Merci beaucoup pour votre aide.
Hello , Hello ,
First of all thank you for your work. Love it!
But I have a big issue with my hosting provider , threatening me to close my website because I use too many resources.
Do you know of or that come from?
Thank you very much for your help.
The theme was tested and designed to use resources in most efficient way and can also be customized to speed up your site.
You can take a look at the PageSpeed topic where many theme users have provided advices on how to optimize your server, page speed, caching, htaccess and set your server settings properly.
If you followed all this and still have issues you should also consider changing you host provider. If that is not an option please contact us via email at contact@tagdiv.com and state your issues details and we will try to find a solution for it.
