Probleme h1 heder
Good evening, please I have a problem with the h1 heading, if I disable the h1 in the logo, the pages become without h1, and if I enable the heading in the logo, there are also multiple h1 headings, please help me to solve this problem. Thank you for your reply
By default, the H1 tag is applied to the logo. If you’re using Cloud, you can use the tagDiv Composer to remove the H1 from the logo (you need to do this for both mobile and desktop views).
Here’s an example: https://i.imgur.com/0BjZdOj.png
When you open an article, the H1 will automatically be used for the article title.
For pages, if you want to remove the H1 from the logo, you have two options:
Use the PageBuilder template and enable the page title, this way, the H1 will be set on the page title: https://i.imgur.com/ElmwJQR.png or, keep the default page template and use tagDiv Composer to add the page title manually, then disable the H1 on the logo.
The H1 tag is important for SEO, so it should always be present on the page, just make sure it’s used in the right place.
The problem has been resolved. Thank you for your response and assistance. Have a nice day.
