problems after updating newspaper to 10.3.9
with version 10.3.6.1 everything is fine. But after updating since this older version to newer ones many problems appear.
What’s wrong?
Best regards, Raimund Felber
What are the problems, please let others know too.
Hi ray274, please let us know all the problems you are facing using our theme!
Of course, but where shall I begin?
side bar plugins doesn’t work anymore, header is destroyed, footer disappeared.
Sincerely yours, R.
Hi ray274, do you use child theme? also did you checked the plugin conflicts? Also dis you made any changes in theme or plugin files? because those are removed when the theme is updated.
Please provide as many details you can about the problems, also a link to your website will help.
Thank you for your understating!
Hi Calin,
I don’t use child theme. In my opinion I use the whole theme and plugins regulary, no
changes with CSS etc.
https://komplementaermedizin-felber.de/
At the moment 10.3.6.1 is running.
How do I check plugin conflicts?
Unfortunately I do not know how your header was before the update, but now is look ok -> https://i.imgur.com/2233jkd.png -> https://i.imgur.com/gKULRAk.jpg
As about the sidebar plugin if is not a tested one -> https://i.imgur.com/zTomuRS.png we can not provide support.
You can check the plugin conflict, by trying only the theme and tagDiv plugins, without extra plugins.
