I´ve read your documentation and look it up online an there is nothing about my problem. When I am trying to create my homepage with visual composer i do not have any themes to upload so i can not costumize my homepage, i do not know if i did anything wrong with the install. I have themes in the other cap of default templates but i select one and it does not take effect. Please help and thank you
I think you refer at Visual Composer elements like blocks, widgets and others. By default should appear but if this are missing follow this link to enable all: http://screencast.com/t/Zz1MnVkIMIFM If the problem doesn’t solve try without plugins, leave just VC active.
Please provide more details if this is not what you mean.
Let me know how it goes!
