hello, i don’t have anymore the white screen issue since i updated to 10.1 but when i want to create or edit a post i have some big problems that make impossible to work with gutenberg, i have to use the classic editor.
For example if i press tab it doeasn’t create a new block, and i don’t have the “+” t create a block after the first, so i have to create one before and drag and drop it after. I can’t add a link by pasting it on a text, it deletes my block. I can’t edit lists…
We have tested this issue and it works fine on our side.
Looks like it comes from WP Rocket, i know WP Rocket is not supposed to be compatible with newspaper but as you may know this is a very important plugin for any wordpress website, do you have any advice to solve the problem or any other plugin to replace this one ?
