Problems for using ARTICLE DISPLAY VIEW – Module 19
I have selected module 19 for article display view. However, the result is not the same as the one showed in official page. All the words in each post are fully loaded instead of partially loaded and result in a very strange layout. Please see attached photos for reference. I hope there is some solution to solve this problem.
problem example
problem photo 2
template photo
This can be controlled by the excerpt length for that module. Please change the excerpt type to letters first, in the general excerpt settings
– https://www.screencast.com/t/pLXJChvddGUb
Then limit the excerpt as you like, for module 19 used
– https://www.screencast.com/t/TDHT37h3nT
