problems importing templates and composer
Hi when i import templates from the library shows things like this, i think is some widget not showing properly, so problems with the composer?
I tried to delete them but no way to make it clickable
https://www.linkpicture.com/view.php?img=LPic63f62333eec31143084530
i really have bad issues with my composer i must say…
Please provide another screenshot.
Also, please make sure that is not caused by a plugin conflict
