Problems in ads after theme update and plugins.
Hello, how are you?
After I update the theme of my site, and the plugins made available by the theme, I noticed that it is not working properly … The banners in mobile and amp mode are not appearing, could you check for me? My site is http://www.portalpadom.com.br and also check inside the posts …
thank you
Problemas em anuncios após atualização de tema e plugins.
Olá tudo bem?
Após eu atualizar o tema de meu site, e os plugins disponibilizados pelo tema, percebi que ele não esta funcionando corretamente… Os banners no modo para celular e amp não estão aparecendo, você poderia verificar para mim? Meu site é http://www.portalpadom.com.br e também verifique dentro dos posts…
obrigado
I have checked your website and on mobile and it seems to return good results. -> https://www.screencast.com/t/lEsUOl3Zc84 Provide a screenshot with the problem if is not what you mean.
friend now I’m having problems in ADSENSE ads See the pictures below, check the red arrow ….
I’m also having problems with ads amp
https://ibb.co/6HhrjFz
https://ibb.co/ZNcmWtX
https://ibb.co/n07x6rf
which app or site did you use to check on iPhone x?
I see there is a problem, what kind of ads are you using? For auto ads you can enter the code in the theme panel here – https://prnt.sc/mxnext
You can also place ad codes in the mobile theme ads section – http://prntscr.com/my5f62
I see an ad below the website, which is unusual – http://prntscr.com/my5h9z
