I have problems in images optimizing & need your help to take a look.
Score = 82 (without cloudflare & W3)
Socre = 62 (with cloudflare-pro plan & w3)
Both sites using plugin EWWW Image Optimizer.
Thanks in advance!
We didn’t do much testing with cloudflare but they should have some compression options for images – https://blog.cloudflare.com/introducing-polish-automatic-image-optimizati/ , you should check the cloudflare admin panel.
Thank you, Emil G.
