Problems in shwoing blocks from Visual COmposer on mobile
Hi there, after updating to V.8 some of my blocks are checked to be hidden on desktop and show on mobile but these blocks are always showing in any size…. any idea? thanks
Hello luquerias,
Provide your website URL so I can take a closer look at it and also, you should provide screenshots with the errors so we can quickly identify it.
https://www.leerenbodas.com/
sorry 🙂
ANd some screenshots: http://imgur.com/a/z0AJb
thanks!
My problems solved after I deactivated your plugin tagDiv Composer. It was causing my problems… there was no need to invent a new Composer, visual composer was alright.
