problems on a page
I am using the “la mode” demo and am having a problem with a page. (see attached image).
1 – The images are darker and the links don’t seem to work (not even putting the title) …
However, I would need an image gallery with links that opens the same larger image, is there a better way to do this gallery? If you have not foreseen a way how can I import a gallery from an external plugin into the page?
2 – There is a blank space on this page that I cannot remove in any way. I think it comes from the header (which I tried to copy as in home)
the site is under maintenance how can i send you the access data to see the page in private?
Thanks for your help
  • This topic was modified 5 years by ermannaro. Reason: image added
Update point 1:
The links now work, but the image is always obscured.
Also is there a way to open the image in popup? If I use link to the image it opens the page for me without the possibility of going back and that’s not good …
I recommend you to use “Inline single image” to have the possibility of pop-up.
Please send an email at contact@tagdiv.com and provide wp-admin access, so we can investigate more into this issue. Also paste a link to this topic so we can easily identify you.
Let us know and we will gladly assist you.
