Hello, I have discovered that there is a problem that I have with the authors. On the authors’ website they only show the same photo for everyone and it does not correspond to the author. (photo_1) Without sent in the articles (photo_3) if the photo is correct. I use an es cloud block (author template 2). (photo_2)
photo_1 link autor.
Photo_3 link entrada.
Photo_3
This topic was modified 3 years by
ludyma. Reason: failure confirmation
I checked your website and it has a lot of errors. The author image is not displayed -> https://i.imgur.com/2BGW9vv.png -> https://i.imgur.com/2YcmtO5.png
Hello, that’s the problem, since I use the cloud modules, everything is slow, or it doesn’t come out correctly, in this case, as you can see, not even the photo, if it comes out and I send you a screenshot, no, it takes a long time to load the menus, these also module of the cloud. Now the authors, I don’t understand, in the end I’ll have to change the subject, how do I resolve that the photos don’t load in the author, but in the entries. How do I make the header load faster?
I think that you need to do a fresh install with the theme and WordPress. I think that you made a lot of changes in the code, or that you use some plugins.
I checked and you use LiteSpeed, this plugin interferes with the theme if you minify the css and js.
Hi, ok, I’ll check in the mirror to see if I see what’s there or what’s interfering. but as for modifying the code, I have not modified anything, I have only used visual modifications in the theme option in the theme panel. but just like always the theme was bad and slow.
The solution of doing a scratch installation is not viable.
As far as I remember, you had a staging and there weren’t so many design-related problems, for example, here in the post too, something is not set correctly -> https://i.imgur.com/VyesJXE.png
Please delete the LiteSpeed plugin, and the files create by this plugin and check after.
Hello, I do not understand why it appears to you, in my verified devices it appears correct. https://imgur.com/myrzEFZ
Hello, I think it is the browser you use, if it is Safari, the theme is not very compatible with it, with other browsers it has no problems.
https://i.imgur.com/lmFPZx1.png
https://i.imgur.com/IKfCDXZ.png
https://i.imgur.com/h5jDrDQ.png
In this screenshot, a low-performance pc, you will see that the menu bar takes a long time to load. https://i.imgur.com/PM9tcEe.png
I would like to take a look, can you please contact us via email at contact@tagdiv.com and provide the wp-admin access?
Hello, I have received this from the hosting, I suppose that you are doing something and it is affecting the performance of the hosting, be careful.
https://i.imgur.com/ySJLzxt.png
This issue is related to the server the last login to the site was yesterday from our side -> https://kinsta.com/blog/http-error-503/
