Problems: smartlist and taboola
Taboola advertising, when I place it in the smartlist, it is placed on top of the gallery control buttons. So I can’t activate it there.
Hello !
Can you send us a screenshot of how and where you implement your ad code ?
https://ibb.co/HqfYmdf
What has happened to me, is that when I place the smartlist, Taboola, it is displayed above the theme buttons. Then I can’t hit the next or previous button.
  • This reply was modified 5 years by kumel69.
Hello !
Please leave the code in and send us a link to a smartlist in order to inspect. Also please make sure that the smartlist selected was installed properly.
Hello !
It looks like your ad is never ending. You will need to remove your ad or create another type of ad.
But at the start, the buttons are not visible.
Hello !
As mentioned above, infinite ads are making it very hard to reach the buttons. As you can see here after a lot of scrolling we have reached them: https://i.imgur.com/xxvdejV.png
Please try and switch from smartlist 6 to smartlist 7. The smartlist 7 has the buttons on top.
Hello !
Unfortunately this is an issue that comes from the ads. Are there any other types of ads that they can offer ? Maybe fixed ads. This infinite ads are breaking the element and unfortunately we cannot do anything about them to fix.
Let us know the result !
