Problems to add content
I have started a new webpage using one of your templates.
I started to add posts a month ago and everything worked fine.
When I should continue to add posts today I get an error message:
Publishing failed. Error message: The answer is not a valid JSON response.
What is wrong?
Site address http://www.destinationmallorca.se
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all plugins and child theme ( if you are using ) and let only the tagDiv Composer , clear all cache, deactivate the cache plugin and try again.
Also you can check these similar topics:
-> https://stackoverflow.com/questions/59009827/publishing-or-uploading-failed-error-message-the-response-is-not-a-valid-json
-> https://wordpress.org/support/topic/the-response-is-not-a-valid-json-response-2/
If the problem persist, please provide some more details and some screenshots.
Hope these will help you!
