Problems using ACF PRO with Tagdiv composer
Hello. I would like to show on this post some of the problems I’ve found while trying to use ACF PRO with tagdiv composer.
1 – Using this settings at ACF https://imgur.com/9MCGou8
2- Filling this at the post https://imgur.com/L7pJUqT
3 – Using this shortcode at the post https://imgur.com/zcyuXly
4 – I’am getting this error https://imgur.com/jzFsR7G
My idea here is to pull the name of the Taxonomy I’ve created and added at my CPT.
  • This topic was modified 4 years by willkar.
If I understand correctly, this problem happens only when the acf shortcode is set in the single external shortcode.
Can you please ty to set the shortcode in column text or text with title to see if the problem persist?
If the problem persists, and you can provide temporary access we can investigate this problem. For this please contact us via email at contact@tagdiv.com, also include the link of this topic to identify you.
Hello. Thanks, I will send an email.
Sorry for opening this again. But since it’s related, I believe it’s better for me to continue using this forum post:
Problem:
I’ve created a taxonomy (https://imgur.com/qY56fFD). But after associating a cloud template to it, I noticed that when I try to edit the template, there are no CPT shortcodes (https://imgur.com/undefined). For example I would like to use the “Single External Shortcode” in order to display the fields I’ve created for the taxonomies (https://imgur.com/undefined).
So my idea here is just to show at the page the custom field I’ve created and then style it.
Another question:
Is it possible for me to show in the taxonomy, other posts related to the specific taxonomy? In my case, I’am using the taxonomy “Developer”. I would like to show all the games (CPT) and news (Defult wordpress category) associated with that taxonomy. If this is possible, how can I achive it? Can you guide me, please?
My goal would be (with real examples from my website:
1 – Game: https://gamingnovato.com/games/rogue-ai-simulator/
2- Developer: https://gamingnovato.com/developer/nerdook-productions/
3 – I want to show on “Developer”, all the news and games associated with it.
I could use the filter option that I found on some of the tagdiv composer blocks, to filter for example by tag, but this manual work is not viable on my case. Is there a more “global” solution for what I’am trying to achieve?
  • This reply was modified 3 years by willkar.
Problem. I just checked and for me the external shortcode appears -> https://i.imgur.com/00gghwk.png -> https://i.imgur.com/42e4MHU.png maybe I didn’t do the same settings like you.
AQ. Unfortunately at this moment this can be done only using the filter from blocks, like you mentioned.
There will be soon an update and this will provide some more flexibility to the CPT.
Hello calin.
You are checking the tagdiv composer for the CPT templates. I was poiting out for Custom Taxonomies (https://imgur.com/s56LysO). Sorry if what I said before was misleading.
Regarding the second thing I point out, thanks for the feedback. Looking forward for that update.
And thanks Tagdiv for the amazing updates. It is giving me the flexibility to do what I have always dreamed of doing without the help of a developer.
Hi willkar,
Thank you for your kind words and for being a part of our community!
Indeed, on the Custom Taxonomies the shortcode is not available, but it can be used the raw html, column text or text with title, in all of those elements can be set shortcodes.
Hello Calin, sorry being annoying but just to point out that the “raw html” suggested, text or text with title does not display the content from the shortcode.
1 – Custom field created at the taxonomy: https://imgur.com/C9JbxmL & https://imgur.com/tmEspdQ
2- I’ve tried all the option suggested (column text, text title and raw html) and none of them displayed the imaged I uploaded at the custom field – https://imgur.com/n3VzdAA. The shortcode is displayed on the page. I even tested it out with a shortcode created with the plugin “Code Snippets”.
Please check this page https://gamingnovato.com/developer/nerdook-productions/ (my website) that display the result that I mention above (note, all the text is black so It might be hard to see it at first)
You have a warning that comes from the code Snippets https://i.imgur.com/lbp5owP.png
Unfortunately, the field image type is not supported, in the next update options will be added to add images.
Thanks for the feedback Anamaria.
Best regards
