Problems View Chrome and Mozilla
Hi, i have some problems in the html view between these 2 navigators, if you enter on the page “http://polosurtdf.com.ar/” with chrome you will se all is fine but dosent show the Ads (Advertisement) on the body the only ads that chrome show is in the sidebar. But if you enter with mozilla you will see correct Ads on body and sidebar but also in mozilla (in chrome shows ok) dosent show correctly the fonts, the image social network on the top page and footer, the scroll image and also the menu header. Plase could you helpme with this issue?
Hope hire you soon.
Regards.
hi, the problem is a plugin on the chrome and the same on mozilla so, its not a problem of the theme.
Thanks anyway.
