Problems visual composer 4.9.2
I have installed newspaper ( Version : 6.6.5 ) on 2 sites :
1 ) in the first automatically installed visual composer . 4.9 and it works fine
2 ) in the second site you have installed ( automatically ) visual composer version 4.9.2 .
Visual composer in this case does not function properly. I tried to uninstall and install again but it does not go. I assume that by installing version 4.9 could solve the problem. How can I do to install the version 4.9 as it automatically installs me the 4.9.2 version?
How can I do to install the version 4.9 of visual composer?
It is always recommended to use the visual composer version that comes with the theme: http://screencast.com/t/eOUcAPnx
Please only use this version. if for some reason this version does not work on your end, please remove all other plugins except visual composer, clear cache and reset cdn files. The plugin is included in the theme package and it works with the theme as it was meant to.
Let us know how it goes.
Hello. Erased all plugins etc but does not work .
Please provide a link to your website so we can inspect the issue.
The site is http://www.universy.it –
I currently have installed a different basic theme because I can not change the home with visual composer. I accurate that on another site I installed the newspaper theme and use visual composer without any problem.
I would like to note that:
1) I managed to install the version 4.9 but the persite problem.
2) Point out that by installing the theme works but I can not edit pages with visual composer as the icon does not leave me to edit pages . Point out that in the mordpress menu appears visual link composer but without the icons.
Opening a page for editing with visual composer does not appear to me the visual icon composer
the bottom of the editing page wordpress I get:
Grazie per aver creato con WordPress.
http://pastebin.com/YARnCyVM
If you changed the theme, how can I see the errors? I do not understand exactly what the problem is. Please send us an email at contact@tagdiv.com and provide wp-admin so we can take a look at these problems so we can provide an answer. Please provide admin rights and please provide as many details as to how visual composer is not working. Also include a link to this topic so we can identify you!
