Problems with 8.6.. Not updated
I do not recommend at all update to 8.6 my web very very slow load now it gets caught not always but every 5 times 1 the bar stays up thinking. I think it’s all for the icons because they have a “nice load lazy load” that causes a brutal slowdown in the loading of the web. I want the old icons with their instant upload, luckily I have not updated to newspaper 8.6 my other websites. Aside from that I have seen that there are problems with the AMP of error 500. Since I am very upset the page is very very slow, please fix the ultra slow load of the new icons.
the problems with amp have been fixed. A new package has been uploaded to envato. Please download the theme again. s for the lazyload of the icons, you can deactivate it from here: https://www.screencast.com/t/mPfDGqbw
Hello precisely that option I have always disabled because that animation slows the web, the case is that it does not work on new social icons
Please try this css code in your style.css file:
.td-js-loaded .td-post-sharing{
transition:none!important;
Thanks Where is put this code ?
I have an issue with 8.6 as well. I tried adjusting via Theme panel and I am not seeing the “Save Button”. None of my changes are going in.
Disable the td-multi-purpose plugin if you have installed it. Run into same issue…
That worked for me, thanks tagdiv-da-best!
Where is this code in? Sorry my english lol
Are you talking about this code:
if so, it was suggested you put that code inside your theme’s style.css file
example:
/wp-content/theme/YourTheme/style.css <–
Thanks but doesnt work… could fix lazy load on icons for the next update ? please
WOW!
@Elevas32
That code will remove the opacity transition set for the icons
– https://www.screencast.com/t/jTDBaPsxmQF
If you enter it in the theme stylesheet or custom code sections of the theme panel, it will remove that transition.
@daodmin
Please clear all caching installed, including browser cache. Purge CDN files if used as well.
