WP Version 5.1.1
When activated TagDiv Composer prevents WP Bakery from showing anything in its dialog boxes. When deactivated it breaks the appearance of the site.
When TagDiv composer is activated you cannot enter or change any data in WP Bakery’s dialog boxes because they are blank. When you turn off TagDiv Composer, WP Bakery works just like it should.
On the previous version, 9.7.2, I could just leave TagDiv Composer deactivated and WP Bakery worked fine, and the site displayed fine. But with 9.7.3 when I disable TagDiv Composer, the block elements built into Newspaper don’t display and images are not sized correctly.
The result is that in order to be able to update my pages and posts that were built with WP Bakery I have to disable TagDiv Composer thus breaking the appearance of the site for visitors.
I have deleted and reinstalled TagDiv Composer as suggested in another thread. I have disabled all plugins as suggested in another thread. TagDiv composer either breaks WP Bakery on the backend when activated, or breaks the look of the site on the front end when deactivated. This is consistent and repeatable.
Please advise. Happy to provide you with login credentials if you would like to see for yourselves. eewc.com Just let me know how to provide them.
Le
Unfortunately in Newspaper v9.7.3 there is a problem between WPBakery and tagDiv Composer, I recommend you to use a previous version -> https://forum.tagdiv.com/topic/important-new-update-newspaper-9-7/
If you need other version of Newspaper theme you can send us an email at contact@tagdiv.com and we’ll provide you the version you need.
