Problems with ACF
The second day I can not solve the problem with ACF. I create fields, but there is no choice in the template editor (just as if there are no fields). The field is in the article when creating, I select the date, but I cannot display it on the page. Inserting a shortcode also does not help.
https://imgur.com/a/5BWoO1a
Hello @Juppiter !
You need to choose ACF field from that dropdown. Or, please try to display manually that custom field like this: https://prnt.sc/O5qwjAgAypP9
Would I write if everything was so simple?) The drop-down list is empty, inserting a tag also does not give anything. It seems that the theme simply does not see the created fields https://imgur.com/a/a5hyTN3
  • This reply was modified 4 years by Juppiter.
Hello @juppiter !
Try to use the element called “Column text” or “Text with title”. “Column text” and “text with title” elements have a button called “edit content” and if you click on that button, the WP Editor will open and you can add some text/code/shortcode there. Close the WP Editor from X, save the changes from Composer and view the page to see the changes.
If this issue is still there, then we need to investigate why it is not working for you.
Contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
Does not work. Wrote an email.
