Problems with Ad Sections (V3)
Recently I have updated the theme to V3. After that I have started having a lots of problems.
First of, the ads are not showing as I want! I have inserted 728*90 Google Adsense code in both Header and Article Bottom section. But the theme is displaying 300*250 in both secrions!
Does anyone knows how to fix that. My site link. i have the ads on 🙂
And, does anyone thinks that the previous function for ads was more better than this?
So I was messing around with the new updated v3 theme and noticed that when using TagDiv Speed Booster it causes your issue. This being said I assume you are using the Speed Booster. Disable it and everything should work fine and wait for them to update it with some fixes
Thanks a lot! That’s working.
Can you tell me one thing? How does tge unique article system works? It is not working on my site at all!
Hello
Please update to 3.0.1 we fixed the Speed Booster issue.
The ad system have some default size defined, if you want to change it go here and edit: http://screencast.com/t/2IcocCo2
We will add this to be changed directly from Theme panel. We built the ad system with easy of use in mind.
To activate the unique article system, edit you homepage and enable it from there. Now you should have no duplicate post on the entire page.
