I get this following error when trying to change the default image used in tagDiv Composer after adding the “Inline single Image” element:
“Invalid data Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)”
I was attempting to change the image that tagDiv Composer used by default in this “Inline single Image” element by clicking on the small thumb of the image near top of left side of it’s settings panel.
I also tried removing the existing image first using the link for that, and then adding an image from the media library. However, this also results in the same error.
I then also tried this same thing by trying to change the default image used in the “Column Content” element, this also results in the same error.
Further, if I exit out of tagDiv Composer and edit using the Classic Editor instead and then attempt to add an image from the media library using the Add Media button it just silently fails with no errors shown. It does open the media library and I can browse/select an image, but the image just never gets placed on the page.
If I use the Backend block editor (WP Bakery Page Builder), choose and add an image element to an existing page this does indeed add an image. Why is this not working in tagDiv Composer or the Classic Editor?
However, in any of the wysiwyg html editors, like provided in a text block in WP Bakery Page Builder, using the Add Media button also fails same as in the Classic Editor.
Please help.
Hello !
Please contact us via email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
