I have a lot of problems with ads on http://www.police-scientifique.com . HEADER Ads aren’t responsive (I would like have 728*90). I try this code for exemple:
<script async src=”//pagead2.googlesyndication.com/pagead/js/adsbygoogle.js”></script>
<!– Responsive –>
<ins class=”adsbygoogle”
style=”display:block”
data-ad-client=”ca-pub-XXXXXXXX”
data-ad-slot=”XXXXX”
data-ad-format=”auto”></ins>
<script>
(adsbygoogle = window.adsbygoogle || []).push({});
</script>
On the Inline ad, you can see on my site, it’s the same problem.
When I use the “top Ads”, I try with responsive and non responsive ads but the ads size is always 300 x 300 (I try to fix adsense size for tablet or desktop, it’s the same problem) !!
Please help me !
I have checked your site and found that you have an error in console so please disable WP-Cleanfix plugin: http://screencast.com/t/1vtVd3ke5B
Please deactivate all plugins and leave only Visual Composer active and check again.Also note that adsense are not responsive on the fly, you have to refresh the window in order to get the right size ads for current screen width.
Thanks a lot !!
I found solution, it was a conflict with the plugin “tagDiv speed booster”. I desactivated the plugin and all si fine now.
Best Regards
