Problems with adsense
we have ads 728 x 90 we put it in the google code in “Custom ad 5” in Newspaper Theme panel then we added “ad box” in visual composer for the home page, but we still get another size ad
one of 300 x 250??
In the bottom near the footer we have a “Text Block” in visual composer with the google code and the them does not display nothing??
Can you help us, its been over a month trying to fix that
Hello masc,
Please check the size for your ad from Custom Ad 1 area, like this -> http://screencast.com/t/hB3HMTU6aR If you leave the auto size, the theme will add the adequate size for your ad depending on where the ad is placed. If you want to have the same size for your ad you have to set it from Ad size from Custom Ad field. For more information about ads, please check our documentation here -> https://forum.tagdiv.com/custom-ad-spots/
We do not recommend using the Text Block for your Ads because this type of Visual Composer element will not render the ad code. You have to use the Ad Box from Widgets Area for footer section -> http://screencast.com/t/RrmSfDR9rzBF.
Hope this helps!
Yes the autos size in the custom ad is like http://www.screencast.com/t/XKt9F8PqrVi
and http://www.screencast.com/t/lb7hJej6V
it is like your documentation, for the widgets is working fine, just for the home page, made with visual composer is the one with trouble
Thank´s
Hello masc,
Please notice that the Adsense is too sensilbe and not every time is adjusted correctly. To be sure it works, please try to set manually the size from your panel and if you want to use in more places the ad you should use many different custom ads.
let us try and we let you know
It worked, with custom size only on desktop, we are working on mobile
