I have problems with adsense banners in http://decoracionyjardines.com
I’ll try to show 3 banners, but your theme can show this.
Regards
http://carrero.es
the banner that you are using here is not made in the adsense panel of the theme: http://screencast.com/t/qpkTvv5nrIn please make it like the others and it will work. It appears on portrait tablets: http://screencast.com/t/BkmdMDsvv and in the rest is hidden.
Radu from tagDiv
I have the same issue,
I am trying to use 3 adsense blocks,
One after 0 paragraph, 1 at the end of the article and one on the sidebar
I used buffy for the ads in the end of the article,
However I am getting blank space for the ads in the right bar (the two rest of the ads are shown)
What should I do?
I can show 3 adsense blocks only if I use two side banners and one in text, however I want to use it in 1 sidebar and to in text,
How can I fix it?
THanks
the theme doesn’t shows all the ads! the google adsense panel from the theme is specifically design to not show multiple ads from adsense for the same spot.
Please follow this: https://forum.tagdiv.com/asynchronous-google-adsense-responsive-ad/
You can use this panel: http://screencast.com/t/NRODccGJdH7v
Radu.
