problems with adsense
Hello guys!
My problem is not with your theme, wich is amazing and I’m proud of using it, but with the ads.
I’ve tried a lot of solutions and your help is my last hope.
I work with a company for a few months with another website, wich is not wordpress builted and the ads works perfectly well. But we are having problems with the ads on the site that I’ve created with your theme. According to them, the ads are shown on the site but they are rejected by the advertisers. Our opinion is that, somehow, the codes the company gave to me are not identifing correctly the site. There is also the bots question, but we have 3 different protections against bots: a wordpress plugin, clouflare and a robots.txt.
This are the scripts the company gave me to install on my site: https://sulvo.bitrix24.com/docs/pub/0967eb7dd9c59c5514ef5cd93dac3f20/default/?&
And this is my site: http://www.vortexmag.net.
Can you give me your oppinion on this? Do you think the scripts are good or do they need some changes? And what changes should be?
Thank you a lot a congrats for your amazing work.
The theme’s ad system only works using google adsense ads or simple ad code (js/flash/images) or its also renders short-codes: https://forum.tagdiv.com/ads-system-full-guide/ Other codes different from this aren’t rendered by the theme.
I’ve tested your code using a wp text widget and also had the same result however the browser displayed this errors in the console which could indicate a code writing error: http://screencast.com/t/qlYegOq6olA – http://screencast.com/t/YUhqoA4PCv
I suggest you go over your code and get someone to help you with this if you don’t have html/js/php knowledge. You can also hire a freelancer from site’s like http://studio.envato.com/ or address this to your ad providers.
