Problems with Advanced Ads
I am using the **Newsmag theme** and I have a serious issue with ad impression tracking when using **Advanced Ads**.
### Problem:
Ad impressions are being **counted multiple times per single page view**.
Example:
* I open a news article once
* The ad is displayed only once on the page
* But Advanced Ads records **1-2-3-4–6… impressions for the same visit (random)**
### What I have already tested:
* Issue happens with **Advanced Ads sidebar widget**
* Also happens with **shortcodes in header**
* Tested with **WP Rocket disabled**
* Tested with **Lazy Load ON and OFF (0px / 200px)**
* Bot tracking is disabled
* GA4 is not responsible (same behavior independently)
### Conclusion:
This clearly suggests that the problem is not related to caching or plugin configuration, but to how **Newsmag renders widget areas or theme templates in the frontend**.
It seems that:
* Sidebar or header areas may be rendered multiple times (desktop/mobile/sticky/AJAX)
* Or the DOM is being rehydrated/rebuilt after page load
* Which causes Advanced Ads to register multiple impressions for a single page view
### Request:
Could you please provide a **fix or official workaround** for this issue?
Specifically:
1. Does Newsmag render widget areas more than once per page load?
2. Is there any known issue with duplicate rendering of sidebars or header areas?
3. Is there a recommended way to ensure that widget areas are rendered only once for ad tracking compatibility?
4. If this is a theme limitation, what is the correct setup for ad placement to avoid duplicated impressions?
This issue makes ad analytics unreliable and directly affects monetization accuracy.
I would appreciate a clear technical solution or configuration guidance from your side.
my website: http://www.redeweb.com
  • This topic was modified 4 months by Albert0.
HI,
I’m not quite sure how this issue clearly suggests that the theme is somehow interfering with the ads. Please note that all that the theme does is to load the ad codes entered in the ad spots or ad boxes, once. Nothing else. It doesn’t load the codes multiple times. If the impression count is incorrect, I suggest looking elsewhere as it’s mot likely not something that is caused by the theme.
I suggest making sure the tracking is set correctly https://wpadvancedads.com/manual/tracking-documentation/
Also checking the troubleshooting guide from the plugin https://wpadvancedads.com/manual/tracking-issues/
I hope the cause of the issue can be found.
