Problems with AMP after Upgrade
freeness . us
Since upgrading to the latest upgrade where the tagdiv no longer handles the amp operations, I no longer have amp pages. I followed all the directions and settings but the amp pages are to longer showing.
The /amp/ pages all redirect to the original post with no /amp/ suffix and without the proper AMP layer.
Thank you
Please use the AMP testing tool when checking if AMP works
– https://validator.ampproject.org/
If you installed both AMP and mobile theme and activated the setting in the theme panel, there would be no problem. Let us know. If there are problems, post a link to the website so we can take a look.
Example url is https://freeness.us/easy-fingernail-hacks-everyone-should-know/
https://freeness.us/easy-fingernail-hacks-everyone-should-know/amp/ now redirects to https://freeness.us/easy-fingernail-hacks-everyone-should-know/ after upgrading to latest newsletter version and installing amp for wordpress plugin.
I do not have any redirects setup for anything with amp in url. I did some research and saw that amp for wordpress plugin had some redirect issues with some users.
What do you need from me to assist in fixing this issue?
AMP is loading but there are a couple of issues – http://prntscr.com/mx9zlh
That first issue could be caused by plugins, there were similar cases before you could check this as a first step.
The second seems to refer to auto ads. How exactly are you adding the AMP auto ads code? Add it in the dedicated section – http://prntscr.com/mxa4zg
Let me know.
You were right, I adjusted a plugin and it looks like everything works as expected now.
I added the auto ads code as you showed.
1. Can you please double check those two issues that they are correctly implemented?
2. Is “/amp/” prefix in the url now supposed to redirect to the none ‘/amp/’ prefix moving forward?
Now it seems valid – http://prntscr.com/my9p3o Also ads appear for me. When the AMP, mobile theme and setting in theme panel are active, the whole website will be AMP on mobile. You can check for verification with this tool
Enter URLs there and check.
I should mention that this verification challenge keeps appearing when browsing and checking the website
– http://prntscr.com/my9q8i I had to click images for a few minutes before being allowed to finally access the website
– https://support.cloudflare.com/hc/en-us/articles/203366080-Why-do-I-see-a-captcha-or-challenge-page-Attention-Required-trying-to-visit-a-site-protected-by-Cloudflare-as-a-site-visitor-
Maybe it happens just for me however, for some reason.
Do I have to use Adsense auto amp ads? How do I set up individual amp ads?
If you want to set up auto amp ads for your website, you need to make the configuration as in the amp-auto-ads documentation-> https://www.ampproject.org/docs/reference/components/amp-auto-ads Also, form ore details about AMP configuration, please check our documentation from here
-> https://tagdiv.com/amp-newspaper-theme/
Hi, the situation is that my sales team wants to have their ad tags placed on the webpages. How can I do this? What do I have to edit to achieve these results?
Am I only limited to Adsense AMP Auto tags?
We have made some tests with Auto AMP Ads and works as expected. You are not limited to this case. Use them!
