Hi Guys,
I have a problem with the AMP post pages since the last update.
You can find the error messages with this post:
https://search.google.com/test/amp ->
https://zentrum-online.at/sommereinsatzbereitschaft-im-noe-strassendienst-wird-fortgesetzt/?amp
I use the settings: “Theme panel -> Mobile Theme -> USE MOBILE THEME FOR -> AMP”
And with the AMP plugin -> Template Mode -> Paired ” (default and can not be changed)
If I deactivate the mobile theme and set the “AMP plugin -> Template Mode -> Classic”, no error message is displayed on search.google.com/test/amp .
The problem is that the AMP classic version does not look very nice.
Your paired version looks very good and worked well before the update.
Please help me to fix the error messages.
arti
If you are not using mobile theme with AMP please use only the classic AMP, because the Newspaper theme do not have a template for AMP, only the mobile theme have template for AMP and the native and paired mode require theme’s templates -> https://www.screencast.com/t/vczzJyUNBE
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
Hi Calin,
I can not use classic AMP. There is no header menu, no footer menu and it is branded by WordPress.
I’ve received more than 100 Google error messages since the last update because of the AMP issue, and sometimes my page will no longer appear in Google search results.
Everything worked great before the update. Please show me a way how to solve the problem.
arti
Were recommend to use the mobile theme with amp, in this way the amp will have the same design like mobile theme.
Mobile Theme: Automatic Optimization for Mobile with Newspaper Theme -> https://tagdiv.com/mobile-theme-automatic-optimization-for-mobile-newspaper-theme/
How to Make an AMP Ready Website with Newspaper Theme -> https://tagdiv.com/amp-newspaper-theme/
Using without mobile theme you can chose to have the classic amp, the other two options require amp templates and our theme do not have slouch templates.
Hi Calin,
I tried to use the mobile theme with AMP and cleared the cache;). Now I have the following three issues.
The Google AMP site test has again shown the same six error messages as without the mobile theme. (I have now disabled the mobile theme again and enabled classic AMP)
With the mobile theme, the featured article is displayed twice.
https://drive.google.com/file/d/19LFwwPd3aZF1igaOuT0JldGe1u4By4-z/view?usp=sharing
and on tablets the mobile page looks strange because everything seems so stretched.
https://drive.google.com/file/d/1Y8_CqMaI1UFJ19q4Cutsb7fMlm3TA9dj/view?usp=sharing
arit
Hi Calin,
Thank you for your patience and the time you spend for me!
The only thing is that the problems are still there and I do not know any further.
If I disable AMP Google penalizes me.
If I use classic AMP the article looks bad and
if I use the mobile theme I have duplicate articles and incorrect display on tablets.
Is there any way to hide the featured article in the latest articles box on moblie theme?
I use the cache plugin recommended by you WP Super Cache so there should be no conflict on tablets.
Please help me! Is there another AMP plugin that can solve these problems, or is there a way to downgrade, because everything worked well before the update.
Many thanks for your help!
arti
If you are not satisfied with our last version of Newspaper you can downgrade to the prev version that you used.
If you do not longer have it you can send us an email at contact@tagdiv.com and ask for the Newspaper version you had.
