I’m not sure what you mean, please provide a link so we can take a look so we can inspect this.
Sorry for the delay, but we answer at the oldest topics first, and because you’ve update yours it has been moved up and we’ve missed it. When you set a background image from theme panel, the theme switch to boxed layout. Your site it’s full layout because you don’t have a background set. Try to set a background color and check if your background is still cut. You can add it here: http://screencast.com/t/qMYTWRByH
Also note that we haven’t tested the Wp Background plugin so the theme could not work well with it.
Hope this helps!
Pleas let us know!
What happens is that the Header is covering up the background.
Part of the Menus.
Can you explain the background of the subject itself, the MENU gets smaller and appears correctly. But disabling the background, the header is in Full.
You can put the header in boxed?
Sorry for delay! Our support program is Monday – Friday: 8:00 AM – 17:00 PM and we answer to the most oldest topics so if you add new replies we get later to your topic.
This is how the theme was designed, when the background color/image is used the site will automatically switch to boxed version, there are some boxed header styles that you can use – http://screencast.com/t/UW1cHxA3gYL also you can try to add a black background color and see if you still have this issue – http://screencast.com/t/F5sjoRqUe
Hope this helps!
