I have upgraded from newspaper 7 to newspaper 9. Everything works almost fine but I have noticed that the bakery visual composer does not work.
When I add any module (columns, rows, images) the opened modal does not show nothing.
When I go back go the older theme (newspaper 7) it works fine again.
same here
If you deactivate the Tag Div Composer, the Wpbakery starts to work again. But if you deactivate the TagDiv Composer the sites goes in errors.
i really dont understand why I’m forced to have the Tag Div Composer active if I dont want to use it. I loved this theme but this thing drive me mad, I hate when some one force me to do something I dont need.
Please notice that we recommend to use only the WPBakery Page Builder plugin that is coming with the theme package.
The WPBakery Page Builder plugin is and Bundled Plugin in our theme not a standalone plugin, please check the envato documentation for those plugins
https://help.market.envato.com/hc/en-us/articles/213762463-Bundled-Plugins
Thank you, I know this but honestly I bought WpBakery Composer a lot of time ago for two reasons:
1- I needed for another site (now closed)
2- I hate to see that it has been updated and I have to wait your theme update maybe two months later, is really annoying: now the plugin has been update to 6.0.3 but your theme as 6.0.2. I will have always the update notification and I dont know when a next theme update will come, maybe months…
So I think you should be provide the compatibility also with the payied version, maybe giving the modified files source so who whants can adapt it.
Thank you
rafpigna.
We are try to provide with our theme update the last version of WpBakery plugin with the changes that are need to work with our theme, unfortunately this is a Bundled Plugin and we can not provide the compatibility for the versions that appear after theme update until me make an update, also for the moment this is not supported as an individual tested plugin in our theme, sorry!
