I have discovered that Big Grid 6 doesn’t look very good on Safari when using style 3. There are some light lines passing between the images vertically.. It can also be seen clearly at the Newsmag demo
Can I fix this somehow?
//Erik
Hi Carllauren,
Thank you for reporting this, I have also tested this on our demo and found the same behavior however we consult determine the reason of it. I have added it on our issues tracker for further testing and we will try to fix it as soon as possible.
Sorry for the inconvenience!
