Problems with Block 11 X Filter
I put 2 categories on filter of Block 11 on my first page, but, when access the page, some categories do not apear.
The system filter que categories writed, and exclude some others categories.
https://app.screencast.com/xOptA6Fv5yUCV
According to your screenshot, you have excluded two categories, so any article that contains one of those categories or subcategories will no longer be displayed on block 11.
https://forum.tagdiv.com/flex-block-settings-guide/ – https://prnt.sc/oiRZX1zxBDGV
Hi Calin,
That part is okay, the problem is that besides those two, some others are also being deleted.
Could you provide an example? Maybe those articles are somehow related to those categories, maybe subcategories of those?
Another situation, if this is a page, then it can also be related to an option that can be applied to teh page, that option is the unique article option https://forum.tagdiv.com/unique-articles/
Hi Calin, I only have 2 pages… Home and Terms of Use.
All the others are Posts.
In Book 11, the “Equipment” category shouldn’t appear, as it already appears on the side of the post through the Widget.
When I add the numbers of 2 categories that shouldn’t be displayed, another category stops appearing, and they are not related, much less nested within each other.
In a hierarchy, they are at the same level.
I understand, but the articles that should be displayed are part of other categories. If
so, teh category will not be displayed.
If you want, we can take a closer look, you can contact us via email at contact@tagdiv.com and provide temporary wp-admin access and some examples.
I have one specific primary category with several subcategories.
If I specify one of these subcategories, the other subcategories of that category X will no longer appear.
HI,
Ok, I made some test and this seems to be working correctly, for example, I excluded the category Street fashion id 81 – https://i.imgur.com/9E0rhTp.png https://i.imgur.com/ftgsfeb.png and the articles from the rest of articles from the same lavel of the excluded category are displaying https://i.imgur.com/3xU4UKt.png
