Problems with Block Setting "Filter"
In Filter tab.
I was choose Category filter is: (Ex: A Or B)
and setting (filter by categories) in Ajax dropdown – filter type : To show only (Ex: A-1,A-2,A-3..Or B-1,B-2,B-3) on my Block.
But they show all Main Category i had (Ex A,B,C,D,E,F…) on my Block
So. how cant i fix that?
Thank you
Same like that
Ex
Hello Nathan,
The ajax dropdown filter works with category id’s. You can get the id like so: http://screencast.com/t/MqtXVVBg
The you need to enter the desired category id’s separeted by comma : http://screencast.com/t/ADd47yg3B45p
You can also filter by author id or tag slug.
