Problems with carrossel jetpack
Hi, I updated the last version of wordpress (portuguese-BR) with Newspaper 4.5d Theme and Jetpack 3.2.1. – and my gallery with carrossel (jetpack plugin) effect stops working. Do you have any suggestion or any reference of this error? The best.
Could please provide more details about the error you have as I have also tested this and tried to recreate it and haven’t found any issues with this.
Please let me know and also make sure that this isn’t happening due to some other plugins you are using so make sure you disable all plugins laving just Visual Composer active and also empty cache and/or purge files if you use any cache plugins or CDN host services and try again.
Thank a lot Lucian. You gived me a great idea. The problem was the last version of AdRotate plugin 3.10.13. It’s stop the “big slide” of newspaper too… I disabled it and now is working fine!
