For my posts I have created some categories and subcategories. For example –> Garten (garden) –> Gemüsegarten (vegetable garden) –> Gewächshaus (greenhouse). When I createad the categories and subcategories they showed up perfectly in the megamenu but since the update most of them are not showing anymore. Garten (garden) is missing as an own categorie, roses is not shown as a subcategorie of Gartenpflanzen (gardenplants) anymore and most of the categories and subcategories are missing anyway. The problem appears also by other categories like recipes, travelling and so on…
The website is found under https://www.topfgartenwelt.com
How do I get it work correctly again?
Greetings Kathrin
This topic was modified 6 years by
Topfgartenwelt.
Topfgartenwelt.
Ok, but why it doesn’t show all categories in the first and second line at all? That is the biggest problem. Most of the categories are missing!!! They are not showing up!
Greetings Kathrin
I have created the megamenu in the following way:
Familie (categorie) with the following subcategories:
– Bei mir daheim
– Belletristik
– Deko (here it shows the subsubcategorie Ostern next)
and the following subcategories are missing:
– Endometriose
– Kinderbücher
– Kinderwunsch
– Schwangerschaft
All the other categories show the same problem: the first 4 categories are shown, but the rest is missing. Before the update there was a drop down option but this one is lost. The mega menu is set up correctly in design (appearance –> menu). So how I can get back the dropdown-option and is there a way that a subsubcategorie like easter is shown like such one? Everything in the menu looks as the same, there is no more difference if its a subcategorie or not. The standardpack is disabled.
Thank you very much!
Greetings Kathrin
Hello !
Please follow the next picture: https://www.screencast.com/t/BcS4h0GkiiC
Red – Category
Green – Subcategory 1
Purple – Subcategory 2
If that is correct, the Purple WILL NOT BE RENDERED.
Mega menus only display Red and Green !
Hello !
Red – Category
The purple ones are just normal subcategories and no subsubcategories. A subcategory is just Ostern (easter). I found in the composer an option that the display of subcategories was limited to maximal 4. I think that was the problem. Now you can see all subcategories. But before the update there was a drop down option for more than 4 subcategories. I can’t find it anymore.
Greetings Kathrin
Greetings
In Newspaper v10.3.2 the only option for “more” in mega menu is this one -> https://i.imgur.com/xsInCl1.png -> https://i.imgur.com/ERSyPjl.png
