Problems with columns in Visual Composer
Sorry. I’m using google translate 🙂
Visual Composer columns are not being customized. I can only follow the standard stipulated by Tagdiv composer. That is, if I want to set a default 1/12 + 10/12 + 1/12 does not stay. How can we solve this error?
Hello otfonseca,
Unfortunately, the theme was not been tested with this kind of layout, sorry! If you want to use the Visual Composer, please check the following useful guide here -> https://forum.tagdiv.com/how-to-use-visual-composer/ The maximum recommended layout, in this case, is the 1/3+1/3+1/3 layout. Also, notice that if you want to use our multipurpose plugin you can use the 1/4+1/4+1/4+1/4 layout but only for multipurpose elements.
