Problems with font weights / size
we have massive problems with the Tag Div Composer with fonts, font weights, etc.
I like the font-design of the “coffee blog demo” and wanted to rebuild it, but with the same settings it always looks different (more bold, etc.). Often if I change one thing, the whole element suddenly appears in a complete different look and you have to quit and start again.
What could be the problem?
Looking forward to hearing from you
Hello !
Can you let us know what blocks are you trying to edit ? The Flex Blocks are fully customizable using the tagDiv Composer: https://www.screencast.com/t/0Uk6AN33C
thanks for your reply, we have no problems with using it, but it’s not working correctly. We have issues for example with Flex Block 5, with an imported cloud header template (Fashion Pro) and with others.
Best
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
PLEASE NOTE THAT DUE TO THE HIGH SUPPORT REQUEST THE RESPONSE MAY GET DELAYED UP TO 48H !
