hello
My visitors have problems with fonts
Some visitors have top menu in Chinese (example pictures)
http://www.craiovaforum.ro/attachmentstatic.php?attachmentid=2145311
How fix it?
thanks
Hello freaktuning,
Usually, this kind of error appears when using CDN or loading fonts from a different source. Please try to use this solution and take a look at this: http://screencast.com/t/AMjW530CSH6 and this: http://screencast.com/t/dLjEUGGwQUZ
The solution to this issue is simple. You will need to add some code to your .htaccess file like this post suggests: https://forum.tagdiv.com/topic/strange-chinese-symbols-replaced-icons-and-arrows/
Thank you for the message!
The solution you privided changed te font to chinese for all the users
I’m not sure what this means though, Do you have a multi-language installed and one language is Chinese? The solution provided above does not add any language to your site. It simply allows the site to receive fonts properly when other resources are loaded from different platforms like cdn or https or another version of your site www or non www.
It has nothing to do with your content language.
