Problems with footer after update
Hi, after updating my website, I lost many settings.
I’m trying to restore everything alone.
I have a problem that I can’t solve.
The footer on the home page is correct, in the posts it is different, the formatting seems to be skipped.
Here my https://comecosa.it/
The problem is caused by WP BAKERY plugin; please disable it. Usually, this problem can appear when you are using the WPBakery if you have this plugin enables, then please disable it and try again. There may be a conflict between WPBakery and the tagDiv cloud library.
We have long recommended to shift from WPBakery to tagDiv Composer because WPBakery is an old builder plugin => https://i.imgur.com/O4CA0y0.png -> https://i.imgur.com/bFnzNtQ.png -> https://i.imgur.com/mv8AhFU.png -> https://i.imgur.com/IMyLYiY.png
