Problems with Header Menu Items
I am having problems with Header Menu Items. I have updated my theme to the latest version of Newspaper and I am seeing that selectors (in Header Menu) are not really working fine.
When I use an icon, the selector goes to the right not staying below the menu item.
Also when I try to select an icon menu, there are two bars below the Menu Item (one in black and one in blue) when it is supposed just to have one (blue one).
I will show you exactly what happened:
I have reinstalled the theme from Default and it seems to work now
Glad that you managed to solve that!
By the way, is it better to ask questions via forum or via email?
Please use forum for issues that no need wp-acces and you think can be solved here.
