Problems with header
Hello, after update, 10.1, Header template start having problems, not every menu item works. Homepage (Početna) is not working, and last item Kalendar is not working, other categories are working, but when on hover show like it is not working. If I remove Header template and go with default everything works fine, but I would like to keep my custom header.
On mobile everything works fine.
Website https://www.musicpocket.org/
