Problems with homepage
Hello there,
I have a problem in homepage of my website http://www.monaco-baviera.it and I don’t know why.
In homepage, when I push N2 and I try to go in the second page of CASTELLI DELLA BAVIERA, website go in a wrong page.
Could you help me to resolve?
Thanks,
Peter
Hello Peter,
I’ve checked your site and the link takes you to the desired page. It seems to work fine now: http://screencast.com/t/y1YEadfh
Hallo Bogdan,
the problem is not in the menu but in the numbers near footer.
Please check my homepage and test “1, 2, 3 avanti… ” down the block “Castelli della Baviera”.
Thanks,
Peter
I have checked your site and you seem to have a redirect on your links:
http://screencast.com/t/2fcWJJ6IsP , https://en.wikipedia.org/wiki/HTTP_301
Please try to disable all plugins except visual composer, clear your cache and purge your files if you use CDN.
Hallo Bogdan,
I have followed your tips but I have not resolved the problem.
Unistalling every plugin I have seen that this problemit’s caused from Yoast plugin.
How it is possible? How could you help me to resolve this?
Regards,
Pietro
Hello Pietro,
Unfortunately the only thing you can do is check the plugin settings and see if you have something set up to redirect links. If you cannot figure it out, you can always reset your plugin settings to their defaults like so: http://screencast.com/t/qyvsrMP8Yx.
I hope this helps.
