Problems with infinite scroll in template
I made a post: https://nolynskitchen.com/dessert/how-to-make-powdered-sugar-glaze/
Based on the template at the end of the post you will see the footer. After one second, a new post will be loaded. How can I stop this from happening?
Its really frustrating.. the page will never end in this way! Hope you guys can help me..
If you are referring to infinite loading, you’ll need to edit the single post template with tagDiv Composer and disable the infinite loading.
-> https://tagdiv.com/infinite-loading-for-single-posts/ from post -> https://i.imgur.com/yIf6fA3.jpg -> https://i.imgur.com/KeclHLS.jpg -> https://i.imgur.com/4jHIHFY.png
Let me know the results!
Thanks Calin! My problem is solved! You made my day 🙂
