Problems with instagram-feed?
Why does not the instagram-feed works?
Hello !
From what I know there are some changes in Instagram roles so you’ll need a token access from Instagram in order to show the Instagram feeds. There will be a new implementation in our Instagram widget in the coming update that we hope will solve this problem, meanwhile you’ll need to find a plugin that can display Instagram feed.
We are sorry for the inconvenience!
Hi there, any news about the problem?
Thanks, Francesco
Our developers are working to a new implementation of Instagram, I think that this will be ready for the coming update.
Hello – checking in on the Instagram feed, is there an ETA on the fix?
Hi @jamiesharpe,
From what I know there was some changes in Instagram roles so you’ll need a token access from Instagram to can show that Instagram feeds; there will be a new implementation in our Instagram widget in the coming update that we hope will solve this problem, meanwhile you’ll need to find a plugin that can display Instagram feeds.
Sorry for the inconvenience!
