Problems with job cron auto post plugin
I contacted the plugin developer “auto post” and he told me that the problem is the thema, which overwrites, I have been working with Newspaper for a long time and before the plugin worked but now it stopped doing it.
This is what the developer told me after analyzing the problem:
“Hi Pedro,
very sorry for the delay. I’ve had another look and found that it is actually your Newspaper theme causing the issue. I have installed the free plugin plugin which allow you to confirm that yourself here:
https://pysnnoticias.com/wp-admin/options-general.php?page=crontrol_admin_options_page
With the Newspaper theme inactive (e.g. try switching to one of the WP default themes) you can see the schedule WP Robot adds and uses called “sixmin”. Once you use the Newspaper theme it overwrites the schedule to add its own, which causes the WP Robot cron to not work anymore.
This is bad programming in the theme (which is supposed to add to schedule without overwriting any others) and the fault of the theme and not WP Robot. You would have to contact them to fix it or use another theme. As far as I know this issue does not exist with any other WP theme. ”
The only tested and recommended plugins to use with our theme are these ones:
WP Super Cache- caching plugin
Contact form 7- used to make contact forms
bbPress- forum plugin
BuddyPress- social network plugin
Font Awesome 4 Menus- icon pack, supported in the theme menus
Jetpack- plugin with lots of features *it may slow down your site
WooCommerce- eCommerce solution
WordPress (Yoast) SEO- SEO plugin
Wp User Avatar- Change users avatars
WPML – multilingual plugin
Anything beyond this list is not tested and I cannot say for sure if it will work or not.
Unfortunately not all plugins work with our theme and custom plugin implementation is not part of the theme support.
Thank you for understanding.
Hello Bogdan,
I am having the same issue with other plugins… for which I finally understand what is going on !
I don’t whant to be unpleasant but the dev of the plugin told me that “It is very bad programming”…
When the theme is activated, other plugins cron are not listed.
I read the forum and I can see that there is a lot of people complaining about this same problem… I think you should take interest in this… You can be a top sale theme with a cron problem… And if peolple were only using the plugin you recommand… I don’t think they would buy your theme…
I believe this is present on our list, our developer team will take a look. But I cannot provide a time interval for the actions that will be taken if necessary. It may take a while unfortunately, there would be more urgent tasks at hand at the moment. We are very sorry for any inconvenience created.
