Problems with migration
Hi everyone. I have moved my website to a new provider and I am facing some issues in Newspaper 11:
1. I am not able to activate Envato Purchase code. The button keeps loading indefinitely.
2. Some images are not being showed up, although they are available on the server. It doesn’t appear on the page, but if we click open in a new tab, it’s there, as you can try here: https://www.irmaos.com/520-hospitalidade/
3. The sidebar is incomplete on the backend. It is missiong Tags, image and categories.
Has this ever happened to anyone else? Could you please help me to fix it?
Hello Paulinho!
1. Go through the following guide: https://forum.tagdiv.com/general-options-may-interfere-with-newspaper-theme/ to ensure that nothing is blocking this request.
I recommend you use only tested plugins with our theme.
2. Examine the settings or uninstall the Autoptimize plugin to see what happens.
3. Maybe you use the old widget style and that’s why it’s not appearing in the backend, but it should be in Appearance-> Widgets.
Hello Betina. Thank you for your answers.
1. The problem is that the theme was activated before with all the same plugin that we have now. The system said that there was a problem and recommended to unlink and try to activate again. When I try to do that, I can’t. Do you think the problem is that the theme is still activated in the former server? Unfortunately I am not able to reach it anymore. In addition, the link you sent is unavailable.
2 and 3. I’ll try your suggestions now.
The widgets session is totally empty. I don’t know what could have happened. This can be the reason for all the other bugs. Do you have a clue to help me?
Hello Paulinho!
Please contact us via email at contact@tagdiv.com, provide a wp-admin and cPanel URL and credentials, license certificate and purchase code. Our team will take a look and let you know what can be done!
Done. Thank you.
