Hello.
i have made seperate page for my front page for mobile,
and i have set it up under meny and used a link.
but when i click on my website on mobile it shows latest articles.
how do i fix this ??
– marlene.
Hello !
This is not an issue. The designs do not match is because you are using the mobile theme. The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
When i disable the mobile theme it remove all off my layout and only have blue tekst.
how do i keep my layoyt and fix it do go directly to front page ?
hello again.
http://bornogfritid.dk/
this is my website i cant disable my website because we are a magasine and have people in to read our articles and so on…
so i need my website up and running.
but as you can se on the fone is shows lastest artikles and i need it to show my website landing page.
Hello !
I’ve reviewd your page and now is diplayed ok. The latest articles appears only when you have active the MOBILE THEME PLUGIN. https://www.screencast.com/t/uxn4r9unrcg
Hello again. i tried diableing the mobile editor and now all off my layout is gone.
so i dont know what to do…
either i have a landing page that cant be accessed directly
or have a blue landing page.
why does this have to be so difficult ?
Hello !
I’ve rechecked your page. No changes, everything works ok. Please clear your cache and take a look. Or try another browser. Here is what I see: https://www.screencast.com/t/DCN9ZKSbB28
