Problems with Town Talk template
Hello. We are having two issues with the Town Talk template. I’ll detail them for you.
Problem 1: When we create a page, the date remains in English, something that does not happen when dealing with an individual post. It makes no sense because the website is in Spanish, and it’s the same type of block: Single post date, with the same settings. See photos here (single post, ok) and here (page, doesn’t works). Here, link to page
Problem 2: In the Title Over Image block type, we have a row with 4 blocks, and in each one, a Title Over Image module. The block height does not work. All 4 were set to 220 pixels, but it only remains on the last one. When you add a new module within the row, the previous one starts to display vertically. See image here.
You can see the block at the end of the homepage
  • This topic was modified 2 years by llucson.
Hello @llucson!
The date format is the one from the WordPress settings. Please check how you set it there. Settings -> General. If your language is also set to Spanish, then it should display in Spanish and not in English. Clear all the cache and try again.
I can see on your website that the problem is solved: https://app.screencast.com/R3q0kc0amQnOU
The WordPress settings are in Spanish. And of course, logically, I have cleared all types of cache. It’s a problem that has been there from the start. Like I said in my previous comment when it’s a normal post, it displays correctly, but when it’s a page, the language doesn’t display properly. The settings in WordPress are correct, and they replicate well in posts, but not on pages.
2. No. It doesn’t work. I’ve had to set them all to 500 pixels in height to be able to display them for now. But if I reduce the height of the module to 250; that is, horizontally, it gives the error I mentioned before.
  • This reply was modified 2 years by llucson.
Hello @llucson!
Please check the elements that are not translated. It could be a text that you need to change it manually in the tagdiv composer.
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
It shouldn’t be like that. Make sure it is not a plugin conflict there first.
